Service specials
Discussion in 'Allpro Subie Service & Performance' started by Allpro Subaru, Aug 9, 2016.
  1. Allpro Subaru
    Allpro Subaru Registered Vendor
    Feb 21, 2011
    147
    2
    TIMING BELT SERVICE: $950.00
    REPLACE TIMING BELT, TENSIONER, IDLER AND PULLEYS, CAM SEALS, FRONT CRANK SEAL, WATER PUMP, THERMOSTAT AND GASKET, COOLANT
    CLUTCH INSTALLATION: $450 (LABOR ONLY)
    30K SERVICE:
    INSPECT BRAKE HOSE/LINE, CV JOINT BOOT, COOLING SYSTEM, DISC BRAKE SYSTEM, DRIVE BELT, FUEL FILTER, FUEL SUPPLY LINE, PARKING BRAKE SYSTEM, STEERING AND SUSPENSION.
    REPLACE AIR FILTER, CABIN FILTER, BRAKE FLUID, *ENGINE OIL AND FILTER, TRANSMISSION FLUID, DIFFERENTIAL FLUID (F/R), POWER STEERING FLUID, BRAKE FLUID AND COOLANT. ROTATE WHEELS
    MANUAL TRANSMISSION: $ 540.25
    AUTOMATIC TRANSMISSION: $ 554.75
    CVT TRANSMISSIONS: $ 578.15
    * SYNTHETIC ENGINE OIL SLIGHTLY HIGHER
    60K SERVICE:
    REPLACE AIR FILTER, CABIN FILTER, BRAKE FLUID, *ENGINE OIL AND FILTER, TRANSMISSION FLUID, DIFFERENTIAL FLUID (F/R), POWER STEERING FLUID, BRAKE FLUID , COOLANT, SPARK PLUGS, AND FUEL FILTER. ROTATE WHEELS
    MANUAL TRANSMISSION: $920.00
    AUTOMATIC TRANSMISSION: $941.70
    CVT TRANSMISSION: $ 965.10
    * SPARK PLUG PRICES VARY ON VEHICLE
    ** SYNTHETIC ENGINE OIL SLIGHTLY HIGHER
    EXPIRES SEPTEMBER 30, 2016
    CALL TO SCHEDULE APPOINTMENT
    AllPro Subaru, LLC is not affliated with Fuji Heavy Industrial Ltd., Subaru of America, Inc.or any related subsidiaries. AllPro Subaru, LLC is not an authorized Subaru parts dealer or repair shop. Services, labor and parts associated with AllPro Subaru, LLC are not guaranteed by Subaru.
    #1 Allpro Subaru, Aug 9, 2016
    J_P and Drowland87 like this.
