Spring Installation
Discussion in 'Modifications & DIY how-to' started by JJang12, Oct 7, 2004.
  1. JJang12
    JJang12 Active Member
    I'm getting JDM STi Pink springs soon. Should I take it to dealers for installation??? OR is there anyone want to help me up for installation???
    SOG quoted me FOUR hundred and SIXTY dollar + hundred something extra for alignment. crazy.... but i have $500 subaru bucks that I can use.
    Does it really take 5 hours for total installation???
  2. miloman
    my tein flex took a while to install at knowledge... give them a call at 678-445-0688 if u want to get a quote from them... i think it will be in the same ballpark but its worth a try... talk to either melvin or kevin and tell them that milo referred u
  3. yerrow
    yerrow Active Member
    mahdavi motorsports...770-923-1550
    $70 for 4 wheels alignment and shouldn't be more than $225 on install
  4. gotsol
    gotsol Active Member
    You can do it yourself in about 3-4 hours if you are handy.
    It i s a good place to learn about working on your car.
  5. JJang12
    I want to self install this, but i do not have most of proper tools. So i think it'll be easier and faster for done it at shop. I'll call those two places. It'll take a while for my springs to get delivered. Hopefully soon.
  6. JJang12
    yerrow, i forgot what kind of spring you had. it looked pretty good. How much drop did you get??
  7. yerrow
    i went too low with the s-techs. and at mahdavi motorsports it would be $250 with install and 4 wheel alignment. give 'em a call
  8. Genya
    I have done the procedure several times, and have most of the required tools, Im not adverse to help depending on how my week goes. However you will still need an alignment afterwards.
    Jason
