The Life of the Black Knight
Discussion in 'Member Journals & Project Build Stories' started by miloman, Sep 22, 2006.
  1. lostinthewoods
  2. BKiller
    BKiller Active Member
    Sweet. I wanna ride in it!!
  3. miloman
    ^^^ Me too. Wait, I'll go take a ride right now :D
  4. blindfold
    blindfold Active Member
    now i need to get a ride in this, congrats man
  5. BelvnAWD
    Grats Milo! I remember when you were getting frustrated with the 300whp barrier in BK1...:ddirty:
  6. GTscoob
    Good numbers man!
  7. 5spdfrk
    5spdfrk Active Member
    Very nice!
  8. miloman
    Thanks guys :)
    Haha. Yeah I remember that.
  9. rexrocker
    Congrats buddy! Very nice. :bigthumb:
  10. wrxin8or
    verry nice
  11. Deke
    Deke Active Member
    That's sick man, congrats on the suby powwah
  12. Cool_____
    Congrats Milo!
  13. dontcallitarex
    dontcallitarex Active Member
    That's some huge power, milo! Congrats man!
  14. miloman
    Thanks guys. This is keeping me plenty happy :)
  15. BKiller
    so without re-reading 57 pages of thread. Can you give us the quick update on your setup now?
  16. It was cool running into you Milo. Congrats on the new numbers man.
    Car sounds/looks awesome!
  17. miloman
    I should keep it updated in my first post:
    Power Modifications
    Deadbolt SuperZilla 65 Turbocharger
    SMC 2:1 Methanol/Water Injection System with Spec-C Tank
    APS DR525 Front Mount Intercooler
    APS 70mm Cold Air Intake
    APS Turbo Inlet Tube
    APS Dual Vent Blow Off Valve
    DeatschWerks 740cc Injectors
    TGV Deletes
    Helix Catted Downpipe
    Blitz Nur Spec-R Cat Back Exhaust
    ACT 6-puck Unsprung Clutch
    ACT Prolite Flywheel
    Software
    Cobb Accessport with Protuner Reflash by Scott Siegel at Topspeed
    Apexi AVC-R Boost Controller
    PLX R-500 Wideband O2/EGT Sensor
    ECUTEK Data Monitor
    Suspension
    Tein Flex Coilovers
    Whiteline Swaybars
    Bridgestone Potenza RE01R Tires
    Brakes
    Carbotech XP10 Front Brake Pads
    Carbotech XP8 Rear Brake Pads
    ATE Super Blue Brake Fluid
    Goodridge Steel Braided Brake Lines
    Speedbleeders
    Miscellaneous
    Group-N Engine Mounts
    Power Output
    422lb-ft, 433 whp (SAE Corrected, 26psi, 93 octane + 2:1 Methanol/Water)
  18. Weapon
  19. Batlground
    Batlground Active Member
    Didnt BIg Davids make 505whp with the FP Red?
    Those are decent numbers for the amount of boost you are running. But i still think there is more in it.
    Isnt that turbo CLAIMED to make 500whp?
    Only reason why i ask is i have a customer trying to buy that turbo, and i kinda want to talk him out of it now. if that turbo cant make 450whp at 26psi, how the hell is it gonna make 500whp?
    PS: You should change your first post where it says COBB TUNED BY SCOTT SIEGEL AT BATLGROUND
  20. Doug@DBW Motorsports
  21. Doug@DBW Motorsports
    hope you didn't mind me posting your graph.
  22. Brian
    Brian Active Member
    If it's not enough power for you Milo, there's always the GT30R. ;)
  23. miloman
    I was told that it would be between a 7cm2 Red and an 8cm2 Red in terms of spool and power. Now comparing it with a 7cm2 red that Scott recently tuned, he had me on spool be ~100rpm or so, but otherwise the plots we dead on. All the older plots that Doug had tuned had me beat by a lot.
    The AVC-R controls my boost, and on the street, I am set up to run 1.9kg/cm2 (27psi) at peak, tapering to 1.85kg/cm2 (26.2psi) at 6000rpm and 1.8kg/cm2 (25.5psi) at 7000rpm. When Scott tuned it on the dyno, I'm not sure if he had a taper. If he did, it would certainly affect peak power. Maybe he could chime in.
    Done
  24. miloman
    Not at all. In fact, thanks for posting it up. I have been asking Scott to do it all weekend.
    By the way, I think plot #8 was the cleanest one without any breaks. Could you post that one up?
    Hahaha. I don't think I am going to change my setup. I'm happy with what I have :)
  25. Cool_____
    And that's all that matters....
  26. slowwrx
    Maybe you should have Doug retune it, maybe he will see something Siegel is missing.
  27. WJM
    LOL@Matt.
  28. slowwrx
    I didn't mean it that way but there has to be a reason that its not making 500whp. That turbo should be capable of 500whp. If its not making near that then something is wrong. Its easy to overlook stuff.
  29. WJM
    I didnt take it that way either. I just found humor in it.
    It is 40hp off where it should be as a minimum. Doug's SZ55 with stock inlet size made 470hp on C16. That was even with TGV's in it and shit.
  30. miloman
    I agree completely. Compression test came back fine so I am pretty confident that the engine is good. There are a couple things in the car that could use improvement:
    1) Downpipe: I have a cat. It's high flow, but it was on my WRX for a couple years and has been on the STi for a year and a half. Not sure if it is still good or not, and how much of a difference there would be if I was catless at these power levels
    2) EM: Switching to something with an adjustable knock threshold would allow for a more aggressive tune
    Concerning the turbo, it's making enough power for me, at least for now. Switching to a whole different setup is really not worth it for various reasons. First off, I doubt there is a whole lot of power to be gained for the amount of money I would need to spend. The car is probably already close to the threshold of reliability. Secondly, even if I spend the money, who knows if it will make any more power. The problem may be with something else.
    For now, I am not worried at all. As long as comparable tunes on comparable setups make comparable power, I know there is nothing wrong with my car. Now if Scott tunes a similar car and it makes a ton more than me, then I'll be concerned.
    If Doug wants to play with it, he can have at it.
  31. slowwrx
    Lets just take it to the drag strip and see what kind of trap speeds it runs. That will tell us how much power it is making for sure.
  32. siegelracing
    Doug was here while I was tuning. Maybe these cats are a lot more restrictive than we thought... There is not much left of the table.
    Siegel
  33. miloman
    I'm running lower boost in higher gears. I don't think I want to run 28psi in 5th or 6th. I'm sure that would affect trap speed in a big way.
  34. Doug@DBW Motorsports
    I was there when Scott tuned it, like almost all the tunes done here at Topspeed now. I don't think there is anymore I could do to it than what Scott has already done. Scott and I frequently work together on some of the cars that come in so its not like we both didn't take a look at while it was on the dyno. It made the power it did and would not make anymore safely. My guess would be he is running the smaller meth nozzle which wasn't allowing us to run higher boost and more timing. Maybe switching to the M15 meth nozzle and a retune will net more power.
  35. Doug@DBW Motorsports
    Dang... you ninja posted me... Wait aren't you on the dyno now, get back to work.
  36. miloman
    :slap:
  37. monk
    ^ lol
    you could throw a smooth-designed U/P for an extra 10-15hp...?
    wait, milo doesn't have many stickers on his car... he needs MORE stickers it WILL make him t3h f4st0r!!1
  38. miloman
    I have stock headers and uppipe. Not sure how much there is to gain/lose there
  39. WJM
    Well, from the butt dyno on my car...going from the stock header/up from an STi to the ported stock pieces, BPM cross over and the Random tech up was a HUGE gain in around town TQ/response, noticeably faster spool and it feels like it has more top end power.
    Otherwise...it just might be that the kitties are stopping it up at that power level.
    The 0~5hp difference we are used to seeing might only apply to the 'smaller' turbo cars. Aka stock turbo and anything less than an 18G/20G.
    I'm sure someone has a 3inch bell mouth catless that Milo could borrow.
  40. monk
    TurninConcepts did a really nice write-up dyno before/after on IWSTI that i read a few days ago. makes some very good points about the stocker not being "quite there"
  41. Cool_____
    I didn't realize you have a catted downpipe Milo. With a catted downpipe and an internal wastegate I am willing to bet all I own that there is 50 hp being held back.
  42. blindfold
    I have an aps 3.5" downpipe you can borrow if you need to, BUT it has divider and could lead to potential boost creep
  43. miloman
    I doubt I'm going to get an external wastegate. But I really want to drop the cat and throw it on the dyno. I expect it will make a noticable difference with the motor pushing ~27psi.
    Thanks for the offer man, but I think I'm going to wait till I get a replacement of my own.
  44. Cool_____
    Are you concern with the noise of the EWG? If so you can simply route the dump into the downpipe. Makes a HUGE difference in the noise.
    Yeah I can see the cat being a huge restriction at over 22 psi. You are trying to push so much air at that point.
  45. miloman
    Noise is not the concern. I just don't want to have to get a new wastegate and uppipe. Eliminating the backpressure from the cat should help promote engine longevity. The external wastegate should help some but for all practical purposes, I have reached my goals with the car. 430whp is plenty fast. Dropping the cat will probably give me a little more, but I don't want to start breaking things.
  46. BelvnAWD
    Now your life is like a giant, eternal void....
  47. miloman
  48. Cool_____
    That makes perfect sense and I'm happy that you are happy Milo. I wouldn't want to change out all that either. Only reason I'm doing it to mine is I have to replace them anyways when I pull the engine for the 2.5L swap.
  49. miloman
    Over the weekend, I ordered an Invidia V2 catless downpipe and an Invidia N1 racing catback (Thanks Sakari). Being unresonated, I wonder how loud/raspy it will sound. Can't wait till they come in. I'm going to put a wideband bung in the downpipe and have it installed as soon as possible.
  50. oneiguy
    oneiguy Active Member
    Can't wait to hear it. Congrats
