For the month of July we are offering the best pricing ever on all HKS Hypermax Suspension products!! Wholesale pricing is available for only a limited number of items so act fast and get a crazy deal on some of the best suspension available for your STi or WRX!! For those of you hitting the track and want to best handling possible, the HKS HyperMAX IV SP is for you! This "MAX IV SP" is the ultimate sport model for such a high grip radial tire. It will transfer the feelings straight to driver all kinds of information such as tire, road surface condition and traction. It’s a perfect street sport model suspension for people who love to drive fast but still want comfort. Single Tube Damper Design Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride. Dust Boot Protect the shaft from the flying stones. PNE Coating Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment. M Shaft (Φ46 normal type) With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range by optimizing the oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience. Adopted Pillow Ball Upper Mount For more accurate and sharp steering. New Design Needle Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride. Reduction of Unsprung Weight In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles) 30 Step Damping Force Adjustment 30 levels of dampening adjustment allow fine tune adjustment for street, circuit winding roads, highway, or the weight of the vehicle. ____________________________________________________________________________ Want to lower your car but don't want the jarring ride? The HKS HyperMAX IV GT is the way to go! It's perfect for daily street drive with style and performance. You and your passenger can have a comfortable ride even with a low-down. Single Tube Damper Design Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride. Dust Boot Protect the shaft from the flying stones. PNE Coating Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment. "M Shaft" With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range because of the optimized oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience. New Design Needle Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride. Reduction of Unsprung Weight In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles) 30 Step Damping Force Adjustment 30 levels of dampening adjustment allow fine tune adjustment for street or circuit.
