TopSpeed Motorsports is happy to announce that we have been working with another company to build us a high flow Subaru specific water pump. These pumps are coated with a heat dispersing thermal coating and are then assembled using a cast steel impeller with closer back spacing tolerances then the factory water pumps. In road course testing we have seen the factory pumps cavitate at high rpms or even fail. Leading to over heating conditions, or worse a blown motor. With our closer back spacing on the impeller and high flow cast impeller design we have all but cured the cavitation issues, improved water flow, and reduced the power required to move the coolant through the engine. I typical 20-30 minute track session we have seen a reduction in coolant temps up to 20F over the standard stamped steel subaru water pumps. This is a great upgrade for anyone taking their car on the track or autox, or the enthusiust that lives in the southern states and wants some extra cooling. **Includes brand new gasket **Heat Dispersing Coating optional **Fits all TURBO Subaru models Including but not limited to the following -Subaru Impreza WRX ALL YEARS -Subaru Impreza STI ALL YEARS -All Turbo Forester Non-Coated: $179.95 Dispersant Coating: $199.95 CLICK HERE FOR THE TSM STORE
