Welcome to my 2.5RS GM6 - Rally Blue Pearl
Discussion in 'Member Journals & Project Build Stories' started by Dempsey, Nov 19, 2009.
  1. Dempsey
    Dempsey Member
    This was purchased from a fellow RS25.com member, BensonWRX.
    Here are the specs/mods:
    FHI V5/6 Front Bumper, Front Lip and Rear Spats
    Painted side skirts
    FHI Fog Lamp Covers
    FHI Pink Star Emblem
    STi Pedals set
    Prodrive OZ P1 Gold Wheels 17X7
    Toyo T-1 Proxes 215/45-17 (Removed)
    Goodyear Eagle GT 215/45r17s
    Brembo F/R Slotted/X-Drilled Rotors
    Mintex F/R Pads (currently OFF vehicle, plan to install)
    Painted Calipers
    Cusco 19-21mm Adjustable Rear Sway Bar
    Cusco Rear Strut Tower Brace
    UR Underdrive Crank Pulley
    FHI Leather Shift Boot
    Prodrive WR Bilstien/Eibach Suspension Set
    FHI Group-N Strut Top Mounts
    Prodrive RB5 Spoiler
    FHI Red/Clear Tail Lamps
    Sony Roll-down style CD-Player (Planning to remove)
    FHI Compass Gauge (Changed position Nov 17th)
    FHI F/R Leather seats
    Custom Mash Grills for hood scoop, vents and F.Bumper (Removed 11/24/09)
    Stainless Steel Brake Lines and premium DOT4 Fluid
    Kartboy Short Shifter and Bushings
    Kartboy Drop links
    Kartboy Hangers
    Apexi Turbo Timer (Removed November 30th)(Sold December 1st)
    Brullen Catback 3" Dual-tips Exhaust, Medium noise level
    STi Motor Mounts
    STi Tranny Mount
    ACT Stage II Street Clutch
    Whiteline Reverse Front Strut Tower Brace
    Differential Protector
    FHI STi Clear Side Markers (Planning to remove)
    FHI Clear Corners (Planning to remove)
    Trunk Light Add-On
    OEM Shift Knob (Installed Nov 19th)
    OEM Shifter Surround (Installed Nov 19th)
    OEM Pocket Compartment (currently OFF vehicle, Installed November 30th)
    OEM, Off-Vehicle and Misc. Parts
    (Once I have organized and cleaned up these items, I will most likely be selling them)
    OEM Gold 98 RS Wheels (Mounted with 2 new tires, 2 mildly used tires, and one extra tire not mounted)
    OEM Suspension set and Strut Top Mounts
    OEM Rear Sway Bar
    OEM Pulley
    OEM Cassette and CD-Player
    OEM Clear/Amber Corners
    OEM Sidemarkers
    OEM Red/Amber Tail Lamps
    LudeSpeed stage II Turbo Kit with High Flow CAT (Sold December 1st)
    Spearco Top Mount Intercooler (Sold December 1st)
    All sensors/probes/fittings for turbo kit (Sold December 1st)
    Anodized Stainless Steel Oil Return Line (Sold December 1st)
    HKS EIDS Pro
    1+ liter of Super Blue Racing DOT-4 Brake Fluid
    Extra O2 Sensor
    Extra H4 Light Bulbs
    Walbro Fuel Pump (Sold December 1st)
    Dual Feed Fuel Mod (Sold December 1st)
    Greddy EGT/Boost/Oil Pressure Gauges in OEM modded housing (Removed Nov 19th)(Sold December 1st)
    Apexi S-AFC (Removed Nov 19th)(Sold December 1st)
    J&S Safeguard + Knock Sensor (Removed Nov 19th)(Sold December 1st)
    Carbo Fiber imitated Center Console and Shifter Trim (Removed Nov 19th)(Sold in November)
    STi Titanium Shift Knob (Removed Nov 19th)
    I flew up to Detroit to pick this car up on November 17th. It was a pretty decent ride down, I drove partially on that day, and some on the 18th. This car is pretty mint. I bought it with 41,000 miles on it.
    A few pictures from the ride down:
    I went to get the car registered today, but alas, this is where the real adventure begins!
    I decided since the previous owner had it turbo'd and had taken out the check engine light, I'd stop by Autozone to check if it was displaying any codes. Yes :(
    P130 - o2 sensor
    p136 - o2 sensor
    p400 - blocked EGR hole.
    So I drove home, and cleared the codes, checked all the hookups for those items, which were fine, cleaned the EGR valve which seemed to be in good working order. I also started removing some of the extra electronics, Apexi, prewiring for a HKS idle stabilizer, all of the Greddy gauges and JR knock sensor thing. I also found out that there is the stock Subaru keyless entry, but no fobs, and an aftermarket alarm (with fobs), and when I hooked the battery back up, the stock alarm started the parking lights to blink, so I just disconnected that box, and that seemed to fix that. The aftermarket alarm is still functioning though. I also put back in the check engine light, it didn't stay on, so I figured maybe I was okay. So then I went to autozone again to check if there were any codes, but we discussed and said that the OBDii system would have to ready itself, and I'd have to drive for a bit. I drove for about 50 miles, and then went to the emissions, and there were the following codes pending, but not showing on the check engine light yet:
    Misfire cyl 2
    Misfire cyl 3
    Misfire cyl 4
    The emissions guy recommended to check the plugs. I bought new ones. God, it was a pain in the ass to install those, but it seemed to clear the idle up a bit. I ran out of time to go back to get the codes cleared. That's tomorrows mission. I did have time to remove the fake carbon overlay on the dash, move the compass up to the top spot above the air vents, and changed the shift knob to stock.
    So this starts my member's journal. I'll try to update when I can.
  2. Sparta
    nice car sir
  3. oneiguy
    oneiguy Active Member
    Very clean.
  4. XanRules
    XanRules Active Member
    Gorgeous, and great work so far. :)
  5. Max Q
    Max Q Member
    The rear O2 CEL, for all intents and purposes, is a nuisance code. Since it's only good for measuring CAT efficiency, doesn't affect engine performance, and is required to be functional to pass emissions, go ahead and throw one of these in between the rear sensor and the pipe and never worry about a rear O2 sensor CEL again.
  6. XanRules
    it may pop up again from time to time, but for the most part he's correct.
    I had it pop up once after doing the spacer mod, hasn't come back in the past 4 months since.
  7. WRXCoupe
    WRXCoupe Active Member
    Amazingly clean especially for a Northern car.
  8. superdoughboy4
    Oh wow. That is one beautiful 2.5RS. I love the body style of that generation of Imprezas, right next to the '05 gen.
    And 41k miles?! That's awesome! Putting aside all of the errors you've had, you have a car that's nowhere near dying.
  9. Dempsey
    Dempsey Member
    Thanks for the information! This is what's going on currently:
    Update - Codes have been cleared for the misfire, and haven't come back. But the p400 has resurfaced. Researching now....
  10. Dempsey
    Dempsey Member
    EGR solenoid is busted.
  11. superdoughboy4
    Oh that sucks. How much would it cost to get it replaced/fix it up?
  12. Dempsey
    Dempsey Member
    75 for a new one at the dealer. Though I posted up a wtb thread, so maybe someone will have one for cheaper :)
  13. Matt
    Techlord may have one out of his L that he's converting. Should be the same part number.
  14. Dempsey
    Dempsey Member
    Update:
    - Made a temp fix for the EGR Solenoid valve.
    - Got a new catalytic converter installed
    - cleared all codes
    - PASSED EMISSIONS & REGISTERED CAR!!
    - Removed "custom" mesh grill inserts
    - Sprayed radiator flat black
    Before:
    After:
  15. dundunskeert
    dundunskeert Member
    Looks awesome man! I left you another PM on mx5atl...
  16. Dempsey
    Dempsey Member
    Ya, I got your PM. sorry about the slow response, I have been keeping myself busy. Just let me know when you wanna meet up, I'll PM you my details.
  17. Cory
    Cory Member
    Custom mesh removal looks much better.
  18. Dempsey
    Dempsey Member
    Updates:
    - Purchased a UEL header from ebay:
    - Removed all of the aftermarket electronics on the car.
    - Sold all of the aftermarket electronics and a few other things as well.
